Break padel gone very low
Break padel is very down position when breaking
@nitinjoshi check your brake lines for any leaks. Check your brake pads for wear and install new pads. Check your wheel cylinders for any leaks and if they may have seized. Check your brake fluid level and bleed your brakes. That should restore your brakes. If you have never done it, make sure that you get the right person/guide to help you with this. Brakes are kind of important for you and everybody else on the road. Let us know if you need more specific help.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 304
