My videocon ac showing e5 error
Some time My videocon ac showing e5 error
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 39
总计 2,947
3条评论
code L6 what's meaning
由 Nabil Dekess 完成的
E5 error videocon ac and out door not start problem
由 Hasnain Shaikh 完成的
@hasnainsha87010 did you check the answer?
由 oldturkey03 完成的
