跳转到主内容
加入维修社区 - 创建账户
2020 年 5 月发布的 13 英寸 MacBook Pro 搭载了四核 Intel 第八代 Core i5 和 i7 处理器,以及 Intel Iris Plus 645 核芯显卡。(型号 A2289/EMC3456,配备两个 Thunderbolt 3 端口)
MacBook Pro A2289 Display Compatibility?
I've got an A2289 with a damaged display. Part number on the display is 820-02008-A and the EEE code is PXGV. Does anyone know what displays are compatible with this computer? I've heard that 2018-2020 Intel 13-inch displays are all interchangeable, but I've tried two separate good condition displays that I thought fell into that range (part numbers 820-02008-01 and 820-00452-A) and they both had dim backlights after logging in and the first one didn't register the camera. Any suggestions or links to reliable retailers online? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@zp[ the 820-00452-A should belong to a 2016-2017 and it will not be compatible. Check on here for the parts number (look for the 661-xxxxx numbers and the compatibility with your system
这个答案有帮助吗?
得分 1
1条评论:
Thank you! I appreciate it.
完成的
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 758
