How can I tell if the problem is the fuse?
How can I tell if the problem is the fuse? Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
@djlaine17 you can't, until you test it with a multimeter. If you have not done this before, check something like [https://www.youtube.com/watch?v=Kxl-IjEl... |this video for the How-To.
This "micro second it moves an inch" leads me to believe that it is not your fuse. When the fuse is "blown" there is not power going through the circuit. None. That means you would not get ANY movement. The issue you are describing sounds like either a capacitor issue or a motor driver issue. Once you checked the fuse to verify, check the circuit board Vornado Duo Circuit Board Replacement for any obviously damaged looking component or burned traces etc. Post some pictures of what you find/see with your question. That way we can see what you see. Also, make sure that tell us the exact make and model of your fan
指南
难度:
非常容易
2 - 5 minutes
指南
难度:
中等
9 - 10 minutes
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 290
