跳转到主内容
加入维修社区 - 创建账户
型号 DSC-2100。索尼 1210 万像素卡片机
Why is camera not turn ON
Camera not turning on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
由完成的
Yes, I already checked it
由完成的
Start problem not running
由完成的
Camera is 1year old please recover
由完成的
添加一条评论
1个答案
最有帮助的答案
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide 索尼 Cyber-shot DSC-S2100 LCD 屏更换 to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Priyeshcamera 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 1,330
