跳转到主内容
加入维修社区 - 创建账户
三星于 2019 年发布的智能手机,属于中端机型,相较于 A50 机型提升了摄像头性能。
Mobile speaker problem how solve this
Loudspeaker is sometimes working and sometimes not
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@shaikthabrez first you want to rule out that this is software related. Check in your settings on the About tab if there is an update for your software. After that you can try a factory reset but YOU MUST BACKUP YOUR FILES. Pictures, contacts etc will all be deleted. this site will tell you how to do this.
If none of that worked, you want to follow the flowchart for the troubleshooting.
To find the components to test, use this document Component Layout . Use your PDF readers search function to find them based on their description
To replace the speaker, follow this
这个答案有帮助吗?
得分 2
添加一条评论
Dear Shaik Thabrez,
You are required to replace the speakers and speaker chip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shaik Thabrez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 249
