跳转到主内容
加入维修社区 - 创建账户
LG Wing 是一款 LG 于 2020 年发布的主打旋转双屏架构的安卓智能手机。可通过型号 F100 以及随后的版本特定字符进行辨识。
How to change Charging jack
How to change Charging jack in my mobile
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@anil41523 the LG Wing uses a charging port/flex. Replacing that will fix the charging port. You are looking at something like this. This is not an endorsement for the vendor, just an example of what you need for a replacement.
The actual replacement is not going to be easy since there is not much information about this phone. Use something like this video to work on it. Once you have the battery removed, it will be apparent which screws and flex cable to remove. You can always post pictures if you are stuck with this repair.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 356
