How the fix err01
I have cleaned the lens contacts even after doing so the lens is not working in auto mode and the other lens is still working!
https://support.usa.canon.com/kb/index?p...
Err 01 is a lens error in most cases; I've never seen a 5D/6D or 2-digit prosumer camera where the issue lay with the body (outside of the APS-C 70D where Canon acknowledged the issue), it always seems to be bad lenses (the entry-level bodies on the other hand... yeah it can very well be the body). How you can usually tell to really quickly to isolate the camera from the lens is do two tests:
Start there and go from there. If it's the body, the problem lies with the lens contact PCB assembly (it's under the pogo pin assembly used to interface with your lenses). You pretty much have to take most of the camera apart to get to it, so either see if you can find the 5DII SM or a tutorial and assess if you can do it or send it out to a shop with a reasonable hourly rate. This isn't an easy fix anyone can do.
That said before you go through with the repair, see if you can check the shutter count with EOSInfo or ShutterCheck; do not try and repair this fault if the shutter count is well into the 100k range as these only have a ~150k mech shutter. If it has 20-30k I'd go for it; but with anything in the 100k range (even 101k) due to the risks of losing the camera again and needing to do a $250-300 professional repair (or suffer taking the camera apart myself, ordering a shutter assembly and swapping it and praying I got the sensor alignment right) is a risk due to the high count. The camera might last 250k clicks, but do you want to find out you spent a few hundred to fix a major issue to need a shutter 10k clicks later? Unless it's something like a 1D series which can be as high as 400k on the 1DX, don't.
As far as replacement goes, this can go both ways if you have a lot of Canon glass: I would look for a 5DIII (NOTE: You lose the swappable focusing screen but it beats replacing the shutter early) with a realistic click count; skip anything the seller will not disclose, it's high on a camera like this if they hide it or go for a Canon RF Mirrorless camera and buy the EF>RF adapter ($100).
这个答案有帮助吗?
I'm one of the owners at Kurt's Camera in San Diego. We troubleshoot and repair Canon, Sigma, Sony, Fuji, Olympus, Nikon, and much more. We've been around for 50 years.
We have fast turn around time and take repairs from all over the US (through mail-in-service). Happy to answer any questions folks have about lens or camera repair or error codes.
Sometimes it's a quick and easy fix. Would love to be a resource here for anyone, especially if they need it fast.
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 524
