跳转到主内容
加入维修社区 - 创建账户
Murray 品牌骑乘式草坪拖拉机的维修指南和技术支持,该品牌目前由百力通(Briggs & Stratton)拥有。
Why is my engine not starting
I have a 17hp techumseh engine on a Murray riding mower that tries to start but won’t. It fires enough to kick the starter out but won’t go ahead and start. I’ve cleaned carb, set valves, checked spark, (blue) and checked crankshaft key….I can’t figure it out…it was running good until I ran over a motorcycle tire in tall grass I didn’t see….it was still running for a bit after I hit the tire, (it was just the rubber) and then bogged down and died…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@baddeal I wonder if the motorcycle tire did not throw off your timing. How did you check it? what exact engine is your Tecumseh? Something like a Enduro Ohv17 etc. Most Tecumseh ignition module depend on the flywheel key for a proper ignition timing. By your running over the tire, it is possible that this partially sheared the key, which will offset your timing. I would definitely take a look at that and replace the key.
Update (08/06/23)
@baddeal I just received this Tecumseh 4cycle OHV Engines. It is engine specific. See if that gets you a bit closer.
这个答案有帮助吗?
得分 0
5条评论:
I pulled the flywheel and looked at the key…,it was fine. It’s a 17hp ohv..
由完成的
@baddeal I would check to see if it starts if you spray some starter fluid around the air intake. I would check the air gap as well just to make 100% sure it is not ignition related. After that it's a fuel issue. You've checked your carb, so you know the choke is not choking your engine. Your float is working properly and the needle valve does it thing. I believe your tecumseh has a impulse fuel pump. You may need to check fuel delivery to your carb.
由完成的
Sprayed lots of starting fluid….no start…
由完成的
Like I said….it has a blue spark and timing seems to be right…..it hits enough with starting fluid to kick the starter out…
由完成的
@baddeal this 'Sprayed lots of starting fluid….no start…" is weird. With spark it should just kick in and at least give you a few rotations of running. Do you have fuel in the carb bowl?
由完成的
添加一条评论
添加你的答案
Bad_Deal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 381
