跳转到主内容
The Vankyo V7000 (YG551) projector delivers a Full HD 1080p resolution with 3,800 lumens of brightness. It was released in 2020.
How to open device?
How do I open the device? My cats knocked the projector off it's place holder and the focus doesn't work as it should. it seems like the lens was knocked out of its focus track and no longer spins unless I hold it for a long time. But it never gets the focus right. If I could get the body open, I could pop it back into place but I don't know where to start.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
@jayeff
Looks like they redesigned as I don't have those screws at the bottom nor the pieces he pulls out in the beginning of the video :(
完成的
How did you finally open it?? I have a similar issue with the lens, did you discovered what happen??
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @kennediehurt
Here's a video that may give you some clues as to how to open your projector.
I realize that is it not the same model, but mostly manufacturers don't alter things that much between models or if they do not often.
Worth a look perhaps anyway.
这个答案有帮助吗?
得分 3
2条评论:
@jayeff
完成的
@kennediehurt
If the unit has rubber "feet" try removing them as sometimes there are screws underneath. Also check under any labels as they could also have recessed screws there.
Please unaccept my answer as it didn't fix your problem.
Cheers
完成的
添加一条评论
添加你的答案
Kennedie Hurt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 273
