跳转到主内容
加入维修社区 - 创建账户
Vankyo V7000 (YG551) 投影仪提供 Full HD 1080p 分辨率及 3800 流明亮度。该产品于 2020 年发布。
How to open device?
How do I open the device? My cats knocked the projector off it's place holder and the focus doesn't work as it should. it seems like the lens was knocked out of its focus track and no longer spins unless I hold it for a long time. But it never gets the focus right. If I could get the body open, I could pop it back into place but I don't know where to start.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
@jayeff
Looks like they redesigned as I don't have those screws at the bottom nor the pieces he pulls out in the beginning of the video :(
由完成的 分享
How did you finally open it?? I have a similar issue with the lens, did you discovered what happen??
由完成的 分享
I have my grandson's YG551 that his mother wanted to use as a classroom device but it wasn't working. These things are NOT made to be opened. There are some very deep screws that need a long very thin Phillips (I think) screws) which are virtually unreachable (and I have a LOT of different screwdrivers). Plastic push together pieces break when pulled apart. It doesn't take up a lot of room in the trash can.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi @kennediehurt
Here's a video that may give you some clues as to how to open your projector.
I realize that is it not the same model, but mostly manufacturers don't alter things that much between models or if they do not often.
Worth a look perhaps anyway.
这个答案有帮助吗?
得分 3
2条评论:
@jayeff
由完成的 分享
@kennediehurt
If the unit has rubber "feet" try removing them as sometimes there are screws underneath. Also check under any labels as they could also have recessed screws there.
Please unaccept my answer as it didn't fix your problem.
Cheers
由完成的 分享
添加一条评论
添加你的答案
Kennedie Hurt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 44
总计 1,018
