跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 850 G1 发布于 2013 年 10 月 1 日,是一款高端商务笔记本电脑。你可以在此找到维修指南和详细信息。
HP laptop sreen issues.
Screen in my laptop is randomly turning "half-transparent" white, what is more intresting nothing frozes at the beggining, after some time white thing spreads on full screen and start frozing image, it also turn color inverted then, it happens mostly when I close or open my laptop, sometimes it disappears when I start moving it, but not always. I tried to wait some time without moving it but that never works.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@vecti73 It sounds like the display cable is getting pinched. You may have to replace it. You just need to replace the cable between the motherboard and display, not the display itself..
这个答案有帮助吗?
得分 1
1条评论:
I will try...
由完成的
添加一条评论
@vecti73 attach an external monitor to your computer first. What you are describing sounds like a bad LCD at best and worst, a bad GPU based 'nothing frozes at the beggining, after some time white thing spreads on full screen and start frozing image' on this. A bad cable would not care if you just started the computer or not. It would always have the same symptoms. This sounds way different.
Let us know what an external monitor shows you.
这个答案有帮助吗?
得分 1
2条评论:
Yes, another monitor is working good.
由完成的
@vecti73 time to open up the laptop and to check things out. Remove the display cable and evaluate the connectors. Check for tears and corrosion. Next take a look the driver board check for any damaged or « odd » looking component. You can change the cable and see if it does make a difference and after that, change the LCD. There are no schematics for the LCD driver board, so to fix it would be by replacing it.
由完成的
添加一条评论
添加你的答案
Vecti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 437
