跳转到主内容
加入维修社区 - 创建账户
Acer 于 2019 年发布的笔记本电脑,Acer Nitro 5 配备 8 GB 内存(使用正确的硬件可扩展至 32 GB)以及红色背光键盘。
Bezel and hinge broken- Need help replacing.
My laptop was dropped over a year ago and the bezel cracked. It's not been too much of an issue, but more recently the hinge has started to stick and at worst, has resulted in the bezel nearly separating from the screen. The crack in the bezel also means the thin piece of plastic on the side sometimes separates and altogether, the entire screen nearly falls apart if not held together with tape. (very temporary solution)
I will be clear in that I'm someone who knows next to nothing about tech repair, but I do have the help of someone who does, but hasn't done this exact thing before.
I have purchased replacement parts, but I cannot find a good and clear guide on how to replace the front bezel and hinge. Pictures of the damage below.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@samgeorge77840 iFixit does not yet have a guide for this. Try something like this video It is actually one of the better ones to follow.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam George 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 905
