跳转到主内容
Successor to the PowerShot G7 X, the Mark II was released as Canon's flagship model in 2016.
20 个问题 查看全部
Camera does not store picture on the SD card.
Power Shot G7 X Mark II will not save picture on the SD Card. What is wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There could be a few possible reasons why your PowerShot G7 X Mark II is not saving pictures to the SD card. Just to get something super simple out of the way, note that the camera is compatible with 16GB, 32GB, 64GB, and 128GB SD, SDHC, and SDXC memory cards. If your SD card is other than this list, it won't work. Troubleshooting tips:
  • If the "Memory card locked" message appears on the LCD monitor, the write protect tab of the memory card is in the locked position, so you cannot capture or delete images
    • To unlock the tab, slide the write protect tab upward
  • The SD card is not properly inserted or is dirty. Remove the card, check for debris, then reinsert it firmly.
  • The SD card is full. Try deleting some photos or formatting the SD card to free up space.
  • The SD card is damaged or corrupted. Try reformatting the SD card using the camera's menu. If that doesn't work, replace the SD card.
  • The camera's memory card slot is damaged. If other cards also fail, you may need service for the memory card slot.
  • The camera settings are incorrectly set to save to internal memory rather than the SD card. Check the image-saving location in the menu.
  • The camera's firmware needs to be updated. Check for any available firmware updates.
First, I would try a different SD card if you have one available to rule out a corrupted card. If that doesn't work, check the save location setting and any firmware updates. If the issue persists, the camera itself may need service for a faulty memory card slot. Let me know if you have any other questions!
这个答案有帮助吗?
得分 2
1条评论:
SDcards can get corrupted often. If you have a laptop with an sd card slot, try to read the sd card. Maybe format the card to try to fix it.
完成的
添加一条评论
download app to move photos to sd
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Gomes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 288
