跳转到主内容
加入维修社区 - 创建账户
面包机的维修指南与相关信息。
Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
由完成的
When I turn it on, it starts in the middle of the mixing cycle.
由完成的
由完成的
I have the same issue with my Gorenje bm1600wg bread maker.
The 15 and 16 manual programs are failed to operate. After selecting one of them it's skipped to the next program.
I need a hard reset method for this machine. Pls help me!
由完成的
添加一条评论
1个答案
已选择的解决方案
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
这个答案有帮助吗?
得分 1
2条评论:
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
由完成的
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
由完成的
添加一条评论
添加你的答案
Janet Schuroll 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 1,536
