跳转到主内容
加入维修社区 - 创建账户
A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
logic board part number?
Does anyone know the part number for a logic board for an Apple iMac 27" A1 from 2019?
Want to make sure I'm ordering the correct part.
The one listed on here is out of stock and does not look anything like the part in my computer.
Thanks.
Update (06/08/23)
I found it. 820-01236-06.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
look for a number on the board you have it starts 820-
由完成的
@tech_ni - The board number is not the same as the part number! The board number helps you in locating the schematic and board view drawings. Ordering a logic board is a very different task.
由完成的
my logic board says its a 820-01236-A is this compactible with the 820-01236-06. board. Thank you.
由完成的
@michaelmag62245 820-01236-A is a 661-12464 Intel i5 3.1GHz 6-Core 4GB board. The 820-01236-06 is a 661-12475 3.6GHz, 8-Core i9, Radeon Pro 575X 4GB board. Yes, that board should fit your iMac.
由完成的
添加一条评论
2个答案
最有帮助的答案
There are a series of options for this system so you do need to focus in on what you are looking for. Here’s the different CPU versions:
  • 3.0 GHz Core i5 (I5-8500)
  • 3.1 GHz Core i5 (I5-8600)
  • 3.7 GHz Core i5 (I5-9600K)
  • 3.6 GHz Core i9 (I9-9900K)
Once you tell us we can get you the info
这个答案有帮助吗?
得分 1
7条评论:
I don't remember what processor I have in it. I'll see if I can figure it out and get back to you.
由完成的
Hi guys, I've the 820-01236-A Board and I must change the thermal paste and thermal pads and I was thinking about a processor upgrade. Can I use an i9 9900k for replacing my i5 9600k with my logic board? The heatsink is the same? Because I've not found informations about this. Regards and thanks!!!
由完成的
@radament - Yes you can do that! I'll warn you reseating the CPU is quite hard as the spring tension on the heatsink is a bit much. If you mess up you could damage the socket pins which would be costly if you can't straighten them or snap it off.
由完成的
Thank You so much Dan, I bought just a few hours ago an i9 9900k, I'll update the community when the upgrade is done (I hope) :D regards, Have a nice day and thanks for the support!
由完成的
Can someone confirm that i have this correct? I have an older iMac with a 661-12483 logic board (i9) and I can't find an exact replacement. However, based on the information here, I could replace it with a 661-12471 (i5) and it would work? Or any of the others with the lesser graphics processors?
由完成的
显示更多的2条评论
添加一条评论
@jonnybadger with your board number (820-01236-06) you have the option of anyone of these
Apple Part Number 661-12471
3.7GHz, 6-Core i5, Radeon Pro Vega 48 8GB
Apple Part Number 661-12483
3.6GHz, 8-Core i9, Radeon Pro Vega 48 8GB
Apple Part Number 661-12467
3.7GHz, 6-Core i5, Radeon Pro 580X 8GB
Apple Part Number 661-12479
3.6GHz, 8-Core i9, Radeon Pro 580X 8GB
Apple Part Number 661-12475
Apple Part Number 661-12459
3.0GHz, 6-Core i5, Radeon Pro 570X 4GB
Apple Part Number 661-12464
3.1GHz, 6-Core i5, Radeon Pro 575X 4GB
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonny Badger 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 29
总计 1,013
