跳转到主内容
Unable to enter recovery mode
I have an eBay-purchased Moto G Fast locked with a pattern from the previous owner. I've tried to enter recovery mode by holding power+volume down while the phone is powered off, but no response. Even holding that button combo for several minutes yields no result. Volume up+power and the phone boots up as normal. I've tested all the buttons separately and they all function normally, but the phone does not enter recovery mode with power+volume down as suggested online. Any advice would be appreciated!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
With the phone on hold power then press restart. When the screen goes black press and hold power and volume down.
This may not work as it might ask for a pass code.
Connect the phone to a charger then try power and volume down. Some Samsung will not go to the recovery screen without being plugged in so not sure if yours might be the same but worth a try.
这个答案有帮助吗?
得分 1
1条评论:
Also the phone will probably be connected to a Google account so you will need to Google frp for that phone.
完成的
添加一条评论
添加你的答案
Michael Taylor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 655
