跳转到主内容
加入维修社区 - 创建账户
起亚于2005年初在欧洲推出了第二代(JB)车型,北美市场则在2006车型年推出。该车型基于与 Hyundai Accent 共享的重新设计的平台打造。
Power stearing fluid change
How do i fix my kia when stearing wheel makes much nois when turning. Should i drain the old fluid
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@josephchidiadia I am honest with you, I have owned a multitude of vehicles in various state of repair ;-) and never had to change steering fluid. If it makes a noise when you turn your steering wheel, it is most commonly the steering pump (yes, replaced a few of those). The number one reason for that is not having enough power steering fluid in the small reservoir. Always check that first.
If that checks out, then there is the possibility of having an internal leak. That causes the noise by increasing the pressures on the pump. That would warrant a pump replacement. Make sure that the whine comes from the pump and not from the steering rack.
这个答案有帮助吗?
得分 1
2条评论:
I have refilled the reservoir with but there was som old fluid in there. Is is going to help if i pump the old fluid out an replaced it new fluid.
完成的
@josephchidiadia Probably not but you can always try. At least that way it is going to give you peace of mind :-)
完成的
添加一条评论
添加你的答案
Joseph Chidiadia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 1,154
