跳转到主内容
加入维修社区 - 创建账户
Galaxy SIII 的经济型伙伴机型,也称为 Samsung I8190 Galaxy S3 mini 或 Samsung Galaxy S III 等。 另有支持 NFC 的 Samsung I8190N Galaxy S III mini 版本。可通过型号 GT-i8190 识别。
Screen flickers after battery replacement
Hi, I my GS3 mini’s battery was on it’s last leg, so I bought a new battery for it. However, it appears that the third party battery I bought was rated for 1350mAh, while the original was 1500mAh. When I run it on the weak original, no flickering. On the new one, flickering. How do I fix this without buying a new phone or yet another battery replacement? (I bought a Samsung Original)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@stechkid just based on this "on the weak original, no flickering. On the new one, flickering." replace the battery once more. Get it from a different supplier. This appears to be a power issue due to a "bad" battery. Re-evaluate with a new battery.
这个答案有帮助吗?
得分 0
1条评论:
I was just about to buy another original, but then I looked up other solutions and some people were saying that you need to calibrate a new battery, so I used the code and calibrated it and the flickering is gone. I am still going to buy a new battery as I have replaced batteries on other phones, including old Samsungs and this has never happened before, so I am going to buy another from another supplier just in case.
完成的
添加一条评论
The other option to try is recalibration, I was bought another but calibration can fix it in some cases.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
80stechkid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 710
