跳转到主内容
加入维修社区 - 创建账户
GameCube 是任天堂的第四代家用游戏主机。维修很简单,仅需常用工具即可完成。
Disc will stop spinning
My discs will initially start and load up, I can play for a few minutes. Then the disc will stop spinning during game play. I’ve tried cleaning the lens to no avail. Curious if this sounds like a fixable issue? Has happened with multiple games.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Rather than typing them all out again, this thread has a number of potential solutions to the issue you are having, hope this helps!
Disc not spinning in GameCube
这个答案有帮助吗?
得分 0
添加一条评论
This is a very common problem with all disc drives, the disc motor bearings get a tiny bit tight and it doesn't rotate at sufficient speed to recognise the disc, trying adding a tiny, very tiny! bit of oil to the disc motor bearing and see if it works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
M Doe 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 12
过去 30 天: 31
总计 716
