跳转到主内容
加入维修社区 - 创建账户
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disc not spinning in GameCube
Hi, my console is showing a NO disc error, i found that the laser works but the disc is not spinning.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
My GameCube continues to spin disc and never stops even when i open it what to do
完成的
添加一条评论
6个答案
最有帮助的答案
I found an old Gamecube at a second-hand store going really cheap. The catch was, the disc would spin up, and then stop again (with no disc message/indication).
If the drive detects no disc, it won't spin the motor. So if your laser is dying, and it cant see anything, it wont spin the disc.
So it is possible that the laser is dying/almost dead, but there ARE guides out there that may help with this; just google "gamecube laser calibration" and hit the first link.
这个答案有帮助吗?
得分 2
1条评论:
This was my issue personally. Apparently my laser was so dirty it couldn’t see the disk! Thanks for the advice.
完成的
添加一条评论
I've seen this before on some devices, usually it is a burnt out drive motor. but to be sure when you power up listen to see if you can hear the drive, since it will stop spinning when you open the cover.
这个答案有帮助吗?
得分 1
1条评论:
I'm sure that my disk Is not spinning, because I've been listening to the motor. My laser is clean, so I know that that is not the problem. Also, other disks are working and spinning properly and working just fine. This disk may have minor scratches on it, but no major. Please help.
完成的
添加一条评论
I tried putting slight pressure on the top of the console with my hand while bootin up the cube and it resolved my issue. Keep pressure on it until the game loads to the game's menu, otherwise ur bad
这个答案有帮助吗?
得分 1
添加一条评论
Indeed, I had the same problem with my GameCube. The laser module died, but the spindle motor and laser carriage worm drive motor were both fine, as I could hear it both spinning briefly and trying to seek, but finding nothing. Maybe your lens is just really dirty? Try cleaning it with alcohol.
这个答案有帮助吗?
得分 0
添加一条评论
There is a switch near the disc drive, and you need to make sure that the switch is turned on, and that causes the disc to spin. It needs to be held down, and usually it is but maybe something fell off, so try to open the GC and see if the switch is held.
这个答案有帮助吗?
得分 0
6条评论:
what switch???
完成的
nevermind, I know what you mean. I found my issue, I broke one of the pieces on that switch!
完成的
what switch?
完成的
The switch is just behind the optical drive on the right hand side. It's got two toggles on it, hope this helps.
完成的
What's the optical drive
完成的
显示更多的1条评论
添加一条评论
My disk spinning up but it then quickly spins down I've repaired my desk it's fine I believe that this drive's fine it just won't spin up well it won't spin up but just spins down
这个答案有帮助吗?
得分 0
1条评论:
@petermozelewski your question ( I assume that 's what this is) is a bit confusing. How can your drive spin down if it does not spin up? You do want to clarify the question a bit better.
完成的
添加一条评论
添加你的答案
Davidmejia 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 138
过去 30 天: 607
总计 69,683
