跳转到主内容
Refresh of the original BlackBerry Bold. Known in some circles as the BlackBerry Bold 2.
18 个问题 查看全部
Water Repair Bold 9700
How I Can Repair A Water Damage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
完成的
添加一条评论
2个答案
已选择的解决方案
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Guillermo Eirin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,118
