跳转到主内容
加入维修社区 - 创建账户
焊接是一种通过熔化中间的填充金属将两块金属连接在一起的方法。焊接种类繁多,但本文旨在向你介绍电子焊接的基础知识。
removing LED from circuit
have any idea about easily removing LED from ciruit board, because its too risky to remove like IC leg prints...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
A picture would be nice. LEDs come in different sizes and mount in different manners. Are you trying to remove it from the board to use elsewhere or are you replacing it? Why is it to risky to remove like IC?
由完成的
添加一条评论
4个答案
已选择的解决方案
anu mahe, check on here. It is a very good tutorial and should help you out. You might get a more specific answer, if you post an image on here, about the items you want to desolder. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
You can also purchase a de-soldering pump.
This has a spring loaded action that you set by pressing the end down.... heat the solder you wish to remove until it turns back to a liquid state.
Once liquid, press the pump's release button and it sucks up all the excess solder. Job done!
The desoldering pumps are available from around £1 online!
这个答案有帮助吗?
得分 1
添加一条评论
First, get yourself some desoldering braid. It is woven copper braid available at electronic supply stores or online. You just heat up the solder with your iron, then touch the braid to the molten solder and the braid will suck it up by capillary action.
Soldering is one of those skills that responds to practice. Get yourself an old circuit board and practice soldering and desoldering before you work for real. A half hour of practice will indicate the amount of heat to use with your iron/gun and make sure to solder to a clean connection. One of those magnifying lights you can mount to the table will really help see those small connections.
As to irons or guns, I have never had much luck with guns. (pistol grip with a trigger). I have too much trouble getting consistent heat, I do much better with a small iron (looks like a big pencil or pen). For most electronics, You will need a very small iron and fine (small diameter) solder.
http://www.youtube.com/watch?v=x0YxEilyQ... is a good tutorial, and will link to other info.
这个答案有帮助吗?
得分 0
添加一条评论
Get yourself a good solder sucker like a solderpult brand , its amazing and you will never use anything else
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anu mahe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 28
总计 8,942
