跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab E 8.0 是一款由三星电子制造的触摸屏平板电脑,于 2016 年 1 月发布。本页面包含型号为 SM-T377V 的维修信息。
Tablet screen is very dim
Hello! I need a bit of help trying to fix my tablet. I dropped it on it's side earlier, and now the screen's brightness seems to be very low. The device is still working well, I can use it like I would everyday. But the screen is super dim, almost impossible to see in the light and dark rooms.
I assume this may be an issue with the backlight. Is there any way to fix this? :[
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@kayjayy not really. Other than opening it and making sure that all the ribbon cables are still connected and no components have been dislodged. Looks like you might be due for a new display but check it first for the aforementioned. Samsung Galaxy Tab E 8.0 屏幕更换
这个答案有帮助吗?
得分 1
2条评论:
thank you! I will try this when I get home! Is there a guide tp help with the first thing mentioned (making sure ribbons are still connected)?
由完成的
@kayjayy first step same guide. Once the back panel is off, you should see all of the ribbon cables. Check those carefully for nicks, tears and improper seating.
由完成的
添加一条评论
Check the proximity sensorClick to Expand
Deactivate Adaptive brightnessClick to Expand
Increase the Screen timeoutClick to Expand
Keep the screen active while you are using itClick to Expand
Change the Secure lock settingsClick to Expand
Change the power saving mode
Regards,
Diana
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kayla! 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 26
总计 1,588
