跳转到主内容
加入维修社区 - 创建账户
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
Taptic engige or antenna replacement?
Hello. while replacing a battery for Apple watch serie 4 40 mm i damaged a part that sits on the taptic engine.
Looks like is not part of the Taptic Engine though, because is not connected.
It looks more like an antenna board to me. Could you please help me identify the part, and in case help me to find a seller or that?
I searched everywhere and i can't fiund it for sale.
If I look for taptic engine, that part doesn't come with.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
There is a coax connection on the Taptic unit. The cable incomes around from the case side which you can see in the video in the Apple Watch Series 4 Taptic Engine 更换 guide. So you will need to replace the part and if you damaged the cable end that too.
这个答案有帮助吗?
得分 0
2条评论:
Yes i saw and followed that video and the coax socket is what i broke.
So.. any idea what's the name of the little part and or where i can find it for sale in Europe?
完成的
@jacopocanova - it’s part of the Taptic Engine part. Sorry I don’t know where in the EU to find it.
完成的
添加一条评论
@jacopocanova you can get those connectors from Mouser.com in Europe as well, This link is for the US site but the same mouser part numbers apply for the european stores. Parts are inexpensive but Mouser is expensive shipping so you may want to shop around any of the major electronic parts store. I believe Farnell in the UK carries those as well.
这个答案有帮助吗?
得分 0
添加一条评论
The Apple Watch Series 4 is nearing iPhone levels of reparability, with the highly-glued display being the primary remaining obstacle. Beyond that, they say the battery is straightforward to replace. Thanks.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Jacopo Canova 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 881
