How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
这个答案有帮助吗?
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
这个答案有帮助吗?
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
这个答案有帮助吗?
Use wireless charger
这个答案有帮助吗?
Might depend on which model version it is, as the OP didn't specify.
The Moto Stylus 5G (released in 2021) doesn't have wireless charging capability.
The Moto Stylus 5G (2025) model does.
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 50
总计 2,676
2条评论
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
由 jayeff 完成的
هذه المشكله من أهم المشاكل لواجهها
Translation Arabic - English
This problem is one of the most important problems to face.
由 ابو عبود 完成的
