跳转到主内容
加入维修社区 - 创建账户
飞利浦 58PUS8105/12 4K 流光溢彩
Blank Screen- sound works.
Hi,
In need of some advice/ help and having read so many helpful questions, answers and solutions, I wanted to reach out to see if anyone has any idea.
The screen has suddenly gone blank, I’ve tinkered with a few TV’s over the past year or so, so I’m comfortable taking the TV apart etc.
Backlights are fully working so they’re not the issue.
Unplug 1 of the T-Con board Cables and half the screen displays as normal, plug that back in and repeat for the other T-Con board Cable and the other side of the screen works and displays what you would expect.
Clean T-Con Cables and their respective sockets, plug both back in and no image displayed.
Am I correct in assuming this is a Faulty T-Con board or is it likely the Video board is at fault?
Any help would be really helpful
Regards
Shep
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
i have the excactly the same issue. is it fixed with u in the meanwhile and if so what was the fix with u?
完成的
添加一条评论
1个答案
@shep67506 according to your tests, I would start with the T-con board. Your main board is sending the right video signals to the T-con board For now the possibility of a bad main board would be pretty low on my list. If anything, it is something past the T-con board that would prevent your picture from displaying. T-con board first, Then re-evaluate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shep 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,336
