How to remove the Daughter board?
My charging port seems to have problem with the charger cord. Can I replace the charger port on the Model 3622 a ?
@machanik yes you can. This is the part you need. Follow something this video to get to the board.
@machanik yes you are right. Like I said that video will get you to the board. Then you have to remove the flex cables and remove the screws to remove the board. It is actually pretty easy once you are on the inside. If you get stuck on that, post some good pictures of your board, when you have your Coolpad open. That way we can guide you all the way. 在已经存在的问题里加入图片
这个答案有帮助吗?
hanks but this video was not the one I'm looking for to remove the daughter board.
The model I have is a 3622A. The one feature here is a 3300A.
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 31
总计 387
2条评论
I noticed that this is a different model from the one I have which is a 3622A not a 3300A
由 Phill Comeaux 完成的
Thanks but the problem I have with the Coolpad model 3622A is that the screen cannot be removed once you separate the rest of the phone from the screen.
由 Phill Comeaux 完成的
