跳转到主内容
加入维修社区 - 创建账户
宝马公司制造,约翰·库珀 (John Cooper) 经典汽车的现代重生。
Bonnet release cable is broken
Can anyone tell me how to open the bonnet when the Cable relese from inside the car is broken?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
How broken? Is the handle broken but exposed or did the cable break someplace deeper in the car? Where is the handle located? The more info you can provide, the easier it will be to provide an answer.
由完成的 分享
use pliers topull manually the wire
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
George, usually when the cable breaks,it is at the cabin end of the cable and not the engine side. Take a look underneath your your dash, you should be able to see the broken end. Grab a hold with a pair of pliers and pull the end, the hood should pop. There is also the possibility that the cable pulled out of the little bracket at the release lever. You might still open the hood, by holding the sheathing and pull on the cable. A pair of vise grips may make that job easier. I found this little tidbit of information on your Mini on here
"Using a hacksaw blade, you can ease the kidney grills out of the bonnet, this allows you to release the left hand bonnet release by yanking on the cable that runs under the front cross member. You can't get to the right hand one through here though.....
To release the right hand one, pull off the lens cover from the RH headlamp. EEEeek I know!!!!! , but mine didn't break and all i'll have to do is silicon it back on after the plastic clips broke. This reveals a space behind the indicator that allows you to ferret around to locate the release cable that runs over the headlamp and up the inner wing."
这个答案有帮助吗?
得分 3
1条评论:
Posts link to thread about opening the bonnet on a BMW.
由完成的 分享
添加一条评论
Thanks for the tips, I’m still searching for a less destructive method of popping the latches , even if it takes more time or tools to do so.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 45
总计 27,387
