跳转到主内容
加入维修社区 - 创建账户
Asus Transformer Pad TF300T 是一款于 2012 年 4 月发布的 Android 平板电脑。Asus Transformer 的设计包含一个可选的键盘底座,可以将平板电脑“变身”为类似笔记本电脑的设备。
Main charging ports have failed
After some time mine has stopped recharging and has gone flat.
The charger and cable seems fine when checking with a multimeter
When connected with the dock/keyboard it does not charge
When not connected with the dock/keyboard it does not charge
At no time do I recall any sign or smell of burning
How can I charge my TF-300 for further investigation into fixing?
Is there any way to charge my TF-300 through the USB-1 port? Like I have seen other devices charging through a USB-3 port?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@fuzzoffury according to the manual you can. "Charging through the USB port may take a longer time to complete. If your computer does not provide enough power for charging the ASUS Transformer Pad, use the wall outlet instead" Time to repair your charging ports :-)
这个答案有帮助吗?
得分 1
2条评论:
There seems to be a misunderstanding
Can I charge into the usb-1 port on the opposite side from the port usually used for charging on the dock/keyboard?
No matter where the power is charging from?
由完成的
@fuzzoffury Your computer commonly only supplies around 500mA on the USB port which may not be enough to charge the tablet.
由完成的
添加一条评论
添加你的答案
Mark Rienits 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 278
