跳转到主内容
Model A1051 / 4 or 6 GB hard drive
Device will not boot - what might I need to fix?
I have a 1st gen iPod mini. It is 4 Gig. Model A1051. The capacity is not printed on the back though.
We left it in our iPod Logitec speaker system (which also recharges the battery) too long. My wife brought it to me a while back after being connected to the system. It was not working, and the mini was hot to the touch. Not sure if the battery overheated or what.
The device does not boot now. I just hear the hard drive clicking like a stuck record. The battery is the original.
I am sure the drive is shot (unless it just needs a new cable). I know it could use a new battery. I am concerned the hard drive may not be the only thing needing replacement (due to how hot the device got).
I do not want to replace everything (drive, cable, battery, board) since I can get a new one for about the same cost.
I would appreciate any recommendations on how to proceed (fixing or replacing).
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
John Ward, I would definitely start with the battery, it is the cheaper solution. Use this guide to get to it 替换iPod Mini的电池 and the battery is available right here iPod mini Battery as well as many other places. Since you will have to disassemble your iPod anyway, you might want to replace the microdrive as well. Here are the instructions iPod Mini Hard Drive Replacement If you do a good Google search for the battery as well as the drive, I am certain that the repair will definitely be more economical than you might think. Also, consider replacing the HDD with a CF memory card, less likely to fail later on. Hope this helps, good luck.
iPod mini, 1st and 2nd Generation, A1501 battery replacement. Compatible with all iPod minis. Model #EC007-3, EC007-5. One year guarantee.图片
产品
iPod mini Battery
$13.99
iPod Mini 电池图片
指南
替换iPod Mini的电池
难度:
中等
25 - 45 minutes
iPod Mini Hard Drive图片
指南
难度:
中等
20 - 30 minutes
这个答案有帮助吗?
得分 1
1条评论:
Holy Moly. It works. I replaced the hard drive with an old CF card I had, reformatted, restored - and my ipod mini works again! Yippee!
完成的
添加一条评论
添加你的答案
John Ward 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,524
