跳转到主内容
加入维修社区 - 创建账户
iPod Mini Hard Drive Replacement
你所需要的
    1. iPod Mini Hard Drive Replacement, Top Bezel: 步骤 1 中的图像 1,1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      询问修复机器人
      添加评论
    2. iPod Mini Hard Drive Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      添加评论
    3. iPod Mini Hard Drive Replacement: 步骤 3 中的图像 1,1
      • Lift the top bezel off of the iPod.
      添加评论
    1. iPod Mini Hard Drive Replacement, Bottom Bezel: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      添加评论
    2. iPod Mini Hard Drive Replacement: 步骤 5 中的图像 1,1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      添加评论
    3. iPod Mini Hard Drive Replacement: 步骤 6 中的图像 1,1
      • Lift the metal retaining bracket out of the iPod.
      询问修复机器人
      添加评论
    1. iPod Mini Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
      • Use a spudger or the tip of your finger to carefully disconnect the orange click wheel ribbon from the logic board.
      添加评论
    2. iPod Mini Hard Drive Replacement: 步骤 8 中的图像 1,1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      询问修复机器人
      添加评论
    3. iPod Mini Hard Drive Replacement: 步骤 9 中的图像 1,1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      添加评论
    4. iPod Mini Hard Drive Replacement: 步骤 10 中的图像 1,1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      添加评论
    5. iPod Mini Hard Drive Replacement: 步骤 11 中的图像 1,1
      • Lift the battery off of the logic board and lay it to the side of the iPod.
      询问修复机器人
      添加评论
    6. iPod Mini Hard Drive Replacement: 步骤 12 中的图像 1,1
      • Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
      添加评论
    7. iPod Mini Hard Drive Replacement: 步骤 13 中的图像 1,1
      • Lift the hard drive out of the iPod.
      添加评论
结论
取消:我没有完成这个指南。
124等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了633篇指南
26指南评论
I have been tinkering with the iPod classics, the 5th gens and now the iPod minis. I think the minis have a cool form factor and the plug and play for a compact flash card is handy. I have purchased a compact flash adapter to SD card, I then put a 128GB microsd into an SD to micro adapter and now I have 128GB mini. As a note, I did have to format the new card to FAT32 with AOMEI prior iPod restore.
djcfuzz - 回复 分享
Hello good sir i unfortunately speakn't good english but i try best now .. having a good day are you… i am also have a service and for fixing ipods … if you want i will give it too you send me an email albertogeniusipodfixes@gmail.com
Alberto Ambréña de la Cejã - 回复 分享
can i change the type of hard disk
valery labiche - 回复 分享
Yes www.iflash.xyz has good stuff for these or u can just use a CF Card and it'll be Plug N Play…literally
the bongo guy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 164
过去 30 天: 549
总计 126,132
