跳转到主内容
加入维修社区 - 创建账户
Intellivision 是美泰公司(Mattel)于 1979 年发布的一款游戏主机。
Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Did I spell Intellivision correctly?
由完成的
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
由完成的
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
由完成的
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
由完成的
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
由完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Hello, check this from the service manual:
1. Connect the Master Component to TV, plug in power cord, set the Antenna Switch Box to TV and determine that the set works correctly on broadcast stations.
So, make sure that your switch box is set properly.
UPDATE
Here is a link to an online service manual that can further help you narrow things down.
这个答案有帮助吗?
得分 3
14条评论:
Sorry, I didn't know what a switch box was. Do you know where I can get one?
由完成的
This will explain some more http://www.atariage.com/howto/connect.ht... and your best bet would be to try Google to get a switch box. They are still around but hard to find. Not knowing where you are, you might want to try Radio shack as well.
由完成的
Thanks, I found it on AtariAge, and the adaptor is at RadioShack for $4.19. I will buy it tommorow and see how it works and tell you guys. Thanks oldturkey03!
由完成的
Sounds great, good luck to you. Hope it works out and let us know....
由完成的
Unfortunately, it didn't work out. But, I've found the culprit! It's the power supply. It was in the Intellivsion Service Manual. But, does anyone know where I can get one of these. I don't want to have to rebuild it(even though I know soldering pretty well).
由完成的
显示更多的9条评论
添加一条评论
添加你的答案
thelectronicnub 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 40
总计 6,379
