跳转到主内容
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
20 个问题 查看全部
Series 5 Apple watch does not turn on
So recently I got a apple watch series 5 from a friend and asked me if I could fix it. The watch just never turned on or showed any sign of charging. I wanted to come here and ask if you guys think it is a battery or a motherboard issue? I mean, Its brand new but has not been charged for 3 years. Last night I plugged it in and still no signs. I also opened it up, and it looks like the battery is not swelling. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Not been charged for 3 years. There's your answer. Battery is goosed.
这个答案有帮助吗?
得分 1
4条评论:
We will see. I ordered a battery.
完成的
Let us know how you get on.
完成的
Well, It just got here. It started bootlooping, so i thought maybe bad connection. Well, I was right. The connector and battery split in 2. I am so mad right now. I spent $42 and 6 days waiting, and now all of a sudden, when I was trying to unplug it from the battery to plug it in again for a better connection, It just split in 2. It was the battery though, because it had shown nothing with the old battery.
完成的
@strongbow look above
完成的
添加一条评论
Did you check the batteries voltage? I would do that to help aim which way.
这个答案有帮助吗?
得分 0
7条评论:
I did, and it did not even register. Also the battery is thinner than a new one.
完成的
@haw8411 - The battery is no different. Are you saying the original battery has puffed up?
完成的
@dan No it deflated, It got smaller
完成的
@haw8411 - That makes little sense, the proper replacement battery should be physically the same size unless the original battery had puffed up which the do when they have gone bad.
Are you sure the replacement is the correct battery? Does the watch work with it?
完成的
@dan I have not got the replacement battery yet. The original has gotten smaller.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Henry W 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 144
