跳转到主内容
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
7 个问题 查看全部
Camera len don't come out
I press on the lens while it was working then the lens doesn't show up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
LAETH ATHER_81 you can try and fix it first by moving the lens from side to side. It is possible that there is grime/grit/dust/sand in between the lens mechanism. Look at the lens and check it against the lens ring. See if is centered or if it is off center. If it is off-center, a little push on the side that is higher may make a difference. For some really useful tips on this, check on here. I've used a shopvac on a lens before, to assist it with extending. If nothing gets this resolved, you may have to consider replacing the lens.
这个答案有帮助吗?
得分 1
添加一条评论
Try to take a flathead screwdriver and pry the lens up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LAETH ATHER_81 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 249
