跳转到主内容
加入维修社区 - 创建账户
HP 于 2011 年 12 月推出的一款 13 英寸笔记本电脑。其尺寸为 31.9 厘米 x 22 厘米 x 1.8 厘米,重量为 1.5 千克。
Help identifying correct battery replacement
The laptop model number above is incorrect but the correct one wouldn't come up.
The correct laptop model is 13t-d100, the laptop part number is M2K14AV and the SN is CND6389KSW. I believe the HP laptop battery model is 816238-850 (Battery - 3-cell 45WH 3.83Ah LI (VR03045XL-PL)) but i need help confirming what to buy.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@markez I've checked the maintenecae manual as well as with HP and that number looks absolutely correct. You may get more reassurance if you ask wherever you are going to purchase it from. If still unsure, get the numbers from the old battery to compare it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Ezrin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 357
