跳转到主内容
8.0 Megapixels, 3.6x optical zoom, 2.6" LCD Monitor
4 个问题 查看全部
Canon Powershot S80 White vertical lines on screen and photo
White vertical lines on screen and photo won't go away.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I'm not an expert on digital cameras by any means, but I do understand the technology behind them, so here are my thoughts on this problem.
First off, the lines you're seeing obviously aren't an artifact of a damaged screen. On other devices like cell phones with display issues you'll see the problem on the screen but if you take a screenshot it won't show the problem. Here, you're seeing the lines on the saved photos as well as on the display which means the lines are there before it gets saved or displayed.
The only other source for image problems like that is the CCD array that captures the image. I have no idea how to replace that part by itself, but a quick search came up with a complete lens assembly that appears to include the CCD array on AliExpress.
Lens Zoom Unit For Canon PowerShot S80 Digital Camera Repair Part Silver + CCD
这个答案有帮助吗?
得分 1
1条评论:
The CCD could be replaced if it would available. It is the part that is mounted to the back of the lens mechansim and attaches with the flex as shown in step 12 on here https://www.ifixit.com/Guide/Canon+Power... step
Cost is probably more than the complete assembly you've linked to ;-)
完成的
添加一条评论
The vertical white lines.
Lens shutter diaphragm is not closing after the shutter timing.
  1. Shutter blades are sticky.
  2. Solenoid of shutter is non working.
  3. Flex is damaged.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dimensionized 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 247
