跳转到主内容
加入维修社区 - 创建账户
这款支持 5G 的 Moto G 于 2022 年 4 月发布,配备 6.8 英寸 120Hz LCD 显示屏(分辨率为 1080 x 2460 像素)、高通骁龙 695 芯片组,以及广角 5000 万像素、超广角和景深摄像头。型号为 XT2215。
Front Glass Replacement Only
Would like to know if the glass only can be changed instead of the whole LCD? If so what is the difficulty level and skill needed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Ar you talking about what they call a "front panel" here? https://www.ebay.com/itm/284855077835?ch...
完成的
添加一条评论
3个答案
已选择的解决方案
robjr that would be a 5/5 difficulty, if you have never done this before. First off you have to separate the glass etc. from the actual display without ruining the display. For that you need a heatsource (hotplate, heatgun etc.) a separating wire very thin and hard wire, UV loca loca glue remover, and the tools needed to disassemble our phone. Then you need to have UV LOCA glue to re-adhere the screen, of course you will need a UV source, a vacuum source ( to remove any bubbles etc.) and probably multiple other things that I am forgetting.
It can be done but it is not economical for a single screen. The cost for all of this will exceed the cost of a pre assembled screen multiple times. Also, the success rate is relatively low for the first couple of times. If you want to go ahead and do this, there are plenty of YT videos that show you how to do it. It does not have to be model specific since essentially they all changes in pretty much the same way. there are multiple guides on here https://www.ifixit.com/Search?doctype=gu... that might be of interest to you.
这个答案有帮助吗?
得分 5
添加一条评论
R the moto g 5g 2022 front screen the same as the moto g stylus 2022
这个答案有帮助吗?
得分 0
添加一条评论
Yes because the 5g is offered in both Motorola 5g or moto g stylus 2022
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Starnes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 3,266
