跳转到主内容
The Dell Latitude 3340 13.3" Laptop features an Intel Core I5-4200U processor and 8GB of memory. Store photos, music, movies, and more on the 256GB SSD Hard Drive.
No audio from speaker nor the handsfree
How to fix my laptop its speaker is not working (no audio) there's no audio even with the handsfree. How can I fix this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
you can first start y going into settings to check the audio settings because for some reason the audio can say disabled which makes it not play. you can also connect a bluetooth speaker ot the laptop if you have one to temporarily fix the problem.
if it is a software problem follow this guide (Microsoft Audio Guide for windows 10/11)
if it is not a software error you may need to replace the speaker.
Hope this helped.
这个答案有帮助吗?
得分 2
3条评论:
Thank You I solved the problem, it was related to audio drivers.
完成的
glad i was able to help
完成的
@gabesech I appreciate your time thank you
完成的
添加一条评论
添加你的答案
zain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 17
总计 121
