跳转到主内容
The Dell Latitude 3340 13.3" Laptop features an Intel Core I5-4200U processor and 8GB of memory. Store photos, music, movies, and more on the 256GB SSD Hard Drive.
5 个问题 查看全部
No audio from speaker nor the handsfree
How to fix my laptop its speaker is not working (no audio) there's no audio even with the handsfree. How can I fix this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
you can first start y going into settings to check the audio settings because for some reason the audio can say disabled which makes it not play. you can also connect a bluetooth speaker ot the laptop if you have one to temporarily fix the problem.
if it is a software problem follow this guide (Microsoft Audio Guide for windows 10/11)
if it is not a software error you may need to replace the speaker.
Hope this helped.
这个答案有帮助吗?
得分 2
3条评论:
Thank You I solved the problem, it was related to audio drivers.
完成的
glad i was able to help
完成的
@gabesech I appreciate your time thank you
完成的
添加一条评论
添加你的答案
zain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 110
