跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note 8T 的维修信息,这是一款于 2019 年 11 月发布的智能手机。该手机的型号为 M1908C3XG。
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
这个答案有帮助吗?
得分 1
2条评论:
Clean the motherboard with alcohol 90 degree
完成的
If you put a protection on the screen put it off
完成的
添加一条评论
添加你的答案
Lubik 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 606
