跳转到主内容
加入维修社区 - 创建账户
Sanyo VPC S1275 是由松下旗下的子公司三洋(Sanyo)生产的一款 1200 万像素紧凑型数码相机。
The "OK" button does not work
The "OK" button of my camera does not work anymore. Is there a way to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Does it feel like it's somewhat stuck when you press it? If it does, give it a good cleaning by following the advice from this answer by Reed Crosby; you may also want to follow this replacement guide and open the camera (steps 1-5) to check if there's anything under the button preventing it from working correctly.
The button may as well be physically broken: to confirm this, first ensure the control panel buttons are in good condition, then complete said replacement guide and reassemble the device, apart from the function set strip. Now turn the camera on and test the OK btn, you can navigate through the menus by pressing directly on the control panel using a pointed tool like a pencil. If everything works, you just need to buy a spare part and replace it (or salvage for parts from a broken device); otherwise there's a more serious damage and the device needs to be inspected thoroughly
Hope this helps, feel free to ask if you have any more questions
这个答案有帮助吗?
得分 2
2条评论:
Thank you so much for the help! And yes, it does feel a little stuck when I press it. I will try to open the camera to check what is causing the problem. It´sa really good camera and it would be a shame not to use it.
I´ll try to let you know if I can fix it!
完成的
@Francesca Glad it helped, of course feel free to post any updates and let us know how the repair is going
完成的
添加一条评论
添加你的答案
Francesca 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 35
总计 1,131
