跳转到主内容
Fujifilm Finepix S4200 is a 14.0 megapixel bridge digital camera released by Fujifilm in 2012.
10 个问题 查看全部
On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
这个答案有帮助吗?
得分 1
1条评论:
Where can I purchase a new button. My button came completely off?
完成的
添加一条评论
添加你的答案
gazza b 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 1,879
