跳转到主内容
加入维修社区 - 创建账户
一款罗技全尺寸键盘,型号为 K270。通常与鼠标捆绑销售。
Logitech k270 no power
My keyboard Logitech k270 changed batteries but no power still
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Prakash Kumar you did not tell us if it worked before you replaced the batteries. IT could be that the batteries are installed wrong. It does happen so check on that. Double check the power switch make sure that it is working. Sometimes the batteries do not make good contact. See if they actually touch the contacts. If not, you can use some folded-over aluminium foil as extension. Anything after that would require you to teardown your keyboard. Something like this video might help
这个答案有帮助吗?
得分 0
添加一条评论
I have to purchase you keyboard so please contact me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prakash Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 831
