跳转到主内容
加入维修社区 - 创建账户
Sega CD Model 2 是 Sega CD 的改良款,于 1993 年发布,旨在配合更新设计的 Sega Genesis II 使用。
CD drive not spinning
ive found that my sega cd is not reading disks ive had the unit apart and found that the laser will attempt to find the disk but the motor wont spin the caps on the board appear to be fine as do the other components i have attempted to clean the lens to no avail and suggestions as the what the problem could be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Carter Logan make sure that the nylon gears on the the sled drive are in good working order and do not have any broken teeth etc. Make sure they mesh. You also want to check for power on the motor. After that I suggest you check the schematics and measure the caps etc. After all, things are getting a bit weak after 30 years :-) and recapping might just be on order. Use this manual Sega CDto help you with working on your console.
这个答案有帮助吗?
得分 3
2条评论:
motor is getting proper voltage and gears are fine im thinking the laser is bad ive read that the motor wont spin if the laser cant find a disk
完成的
@Carter Logan time to replace it
完成的
添加一条评论
Hi, did you ever find a fix for this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carter Logan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 49
总计 2,169
