跳转到主内容
加入维修社区 - 创建账户
2000 款 Nissan Maxima(代号 A33)于 1999 年 5 月推出,是上一代车型的改款。该车于 1996 年至 1997 年间,由 Jerry Hirshberg 领导的 Nissan 加州拉霍亚设计工作室设计。
Idle its variable engine
Hi
Enybody its now way this problem its, work nomaly when the engine its cold with all rpm , but when the temprature its been 70 dgs celisius and more , its the variable idlle engine run with 1500-2000 rpm only..feels like a kenguru .the onlye errorcodes its comming its P0 420/430 , its been delete many times, i think that have nothing with this problem too fo
https://youtube.com/shorts/VwiKqCwjzyc?f...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
me only instead of clearing the codes I would suggest you check your catalytic converter as well as the O2 Sensors. The behaviour you describe, could definitely be caused by those.
这个答案有帮助吗?
得分 0
2条评论:
Have delete the codes some times and the o2 sensores have been replemented for few years ago and never have no problem with the emission , forget to wtite about the idle in start of the engine go the idle down to almost stop and uo agin , look like the airmassesensor its works in short time...
由完成的 分享
@me only yes I was thinking mass air flow sensor as well. My concern is that bad O2 sensors and a bad catalytic converter can do the same thing. You can check the O2 sensors and see if they are functioning. All you need, is to measure the amperage drawn by the sensor with a cold exhaust. It should be between 0.25A to 1.5 amp. Anything else shows they are failing.
由完成的 分享
添加一条评论
添加你的答案
me only 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 505
