跳转到主内容
My phone display shaking and flickering after dropping
My phone display is shaking up and down (like a glitch) and some parts of the display are black mainly at the corners. I could also see some cracks on the edges of the screen.
What could be the problem and how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
شاشة هاتفي بها حبر ازرق وبنفسجى اثر خبطه على الشاشة وكانت صغيره مثل وضع أصبع وبعد ذلك زادت مساحتها بعرض وطول عقلتين أصبع ماهوا الحل بدون تغير الشاشة
完成的
@Mohamed esawy
The is no other option.
The screen will have to be replaced as it cannot be repaired.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi
When this sort of thing happens it usually means that the display is internally damaged but I have had luck reseating the connector on the board
But because your display has cracks in it it will most likely need replacing
Here’s a guide in replacing the screen for your phone
https://m.youtube.com/watch?v=h9uETgnfzD...
Also here’s the part you will need too
https://www.ebay.co.uk/itm/255668681891?...
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 6
1条评论:
I'm already replace my display but rather display is automatically touched why is this like ?
完成的
添加一条评论
添加你的答案
Ajeeth kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 1,022
