跳转到主内容
加入维修社区 - 创建账户
一款由微软推出、具备 4K 视觉效果的高性能游戏主机。型号:1787
How to maximize air flow?
This heated up until the point of melting the HDMI port so I have some video issues, but I don't need that addressed right now, I just need to do some thing about the heat.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
you could try something like this and set the fan speed you want, https://www.ebay.co.uk/itm/191959658526
这个答案有帮助吗?
得分 2
10条评论:
Won't that kick me off of live?
完成的
@nytryder26 its only a speed regulator
完成的
@tech_ni I already opened and cleaned it, It gets so hot It doesn't work properly, now if the case is off it works better but I want the case on so how can I fix this?
完成的
@nytryder26 did you change the thermal paste ?
完成的
@tech_ni No, but I feel the heat on the heat sink so?
完成的
显示更多的5条评论
添加一条评论
此回答最初是针对另一个问题
I'd go with the Amazon one. Doesn't involve opening the console and set it to auto and forget it. Beware the more cool air going in the more dust getting into the system too.
这个答案有帮助吗?
得分 2
5条评论:
完成的
@nytryder26 did you replace the thermal paste?
完成的
@strongbow No, but I feel the heat on the heat sink so?
完成的
@nytryder26 I'd replace it, it dries out over time. Helps take the heat away from the cup.
完成的
@strongbow I touched it and its still moist
完成的
添加一条评论
此回答最初是针对另一个问题
@nytryder26 the issue is going to be that even if you install a fan, your airflow is just not there. You might even create more heat with it. You will have to modify the case to allow the air to pass through. If you are serious about making this work, I'd take the case to an automotive body shop (or sheet metal fabricators) and see if they can "punch" a couple of louvres in there. Then install the fan in a way that it pulls the air through instead of trying to blow on the circuit boards.
这个答案有帮助吗?
得分 1
8条评论:
You know the fan in the ps5, it has the same fan but it's blowing hot air at hot air bc Microsoft did not put a vent by the fan in this model. Who can I get to punch some holes in the plastic case?
完成的
@nytryder26 any good fabricator can do that for you. Again I rely on body shops a lot for this type of mod. Even with plastics since they now deal with that now too.
完成的
@oldturkey03 Ok, thanks for the response.
完成的
@oldturkey03 Do you know any that I can search for?
完成的
@nytryder26 what's your next bigger city ;-)
完成的
显示更多的3条评论
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 769
