跳转到主内容
加入维修社区 - 创建账户
一款配有 7.0 英寸高分辨率显示屏和 Garmin Real Voice 语音导航功能的 GPS 设备。
How to add memory with a microSD?
Need to add memory to download map info. How do I get into device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Keith Sherper check on here for how to install the SD memory card. No, you cannot add any other memory to this device. From Garmin "Garmin Express will only install a map update to a memory card if there is not enough space on the internal storage of the device
  • Maps cannot be moved from the device to a memory card manually
  • Instructions on where to insert the SD card/microSD card can be found in your Device's Owner's Manual"
Now if you still want to get into the device, check something like this video
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Keith Sherper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 437
