Why does my game cut off?
Certain times I can play for a while fine. Other times I play for a bit, and the game will cut out. Now it's pretty much cutting out after reading and loading the disc. The signal cuts out and the power light indicator turns off, but the fan continues to run, and the disc continues to spin. I have vacuumed the side vents with a brush attachments, which worked for a short period.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
7条评论:
@johnnyboy11
Does it do it with specific games or across all games
完成的
It has done it with all games
完成的
@johnnyboy11 have you tried opening it up and cleaning the game slot?
完成的
I have not opened it up, as I have no knowledge of what I should be looking for
完成的
@johnnyboy11
Sorry about the delayed reply (I didn’t get a notification)
Try cleaning the connector for the disk drive with some isopropyl alcohol
The alcohol with help remove any invisible dirt that our human eyes can’t see
Also do you see any corrosion anywhere (white ,blue green marks )
If you do try cleaning it away with some isopropyl alcohol:-)
Also here’s the guide you will need to open it:-)
Nintendo GameCube 光驱组件更换
完成的
显示更多的2条评论
添加一条评论
